Triple Monitor stand?
19 Jun 2012
Liverpool
Any ideas on a make or model of a stand to get hole of? it'll have to hold at least a 27 inch screen and maybe 2 22inch screens?
Ste
Ive got 2 versions Ergotech and the XFX and would recommend the Ergotech stand.
Ergotech has the smaller footprint and with the Ice cube takes less cable mess.
And with the telescope arms can support up to 30inch monitors :)
Trust me the Ergotech one is worth every penny.
It's got so much available modifications.
The XFX not so much as its fairly bulky with its base and does not support the bigger screens.
My Ergotech:
I think there is a version called the Ergotron... but it does not take anything above 21 inches.
Think i saw some also on the bay... which are NON adjustable... on a curve bar.
If you want three that have VESA mounts it's almost impossible. I was searching just a week ago and got recommended the LG 23ea63v. Apparently it's got a fast response time with no ghosting when gaming.
well if i did get the thin bezel i wouldnt mount them at all, juts have them on my desk,
I currently have a 27Inch AOC e2795Vh
Ah, in that case you have more options. AOC do a thin bezel version but it's classed as a low end monitor, so I have no idea what colour reproduction and response time is like.
There is also the ASUS MX239H. There is one or two more but I don't remember what they are at the moment.
