Triple monitor tight space
10 Nov 2011
Telford
Right contemplating swapping my 24" with my sons 22" and gettng 2 more 22" monitors.
The only problem is I am very very tight on space.
wall to wardrobe is 110cm depth isn't an issue.
Is that enough space to fit 3 22" monitors in or would it need to be more?
A quick look at OcUK shows widescreen 22" monitors be around 475-515mm wide.
If you only have 1100mm to play with it looks like you'd struggle unless the side monitors were set at quite an angle.
120 degrees between centre and side monitor for 515mm width of monitor [assuming thats including the bezel] 131 degrees for a 475mm width [this is going off surveyors suggestions]
looks rather tight from what i'm seeing, can't say it'd be the ideal i'd choose.
I'm currently running a 23" triple monitor setup and it's approximately 130cm at about a 135 degree angle between each monitor. The monitors have a very thin bezel too so hopefully that'll help somewhat.
I'm currently running a 23" triple monitor setup and it's approximately 130cm at about a 35 degree angle. The monitors have a very thin bezel too so hopefully that'll help somewhat.
yeh was gonna say my sons 22" monitor is 51cm wide so 3 X 51 =153 - for the slight angle.
Also considering getting a corner desk thats 80 X 80 so that should have the space
For an idea of a corner desk I added a little extra to mine and did this:
Maybe some more ideas for your corner desk scouting. :) These pics are from 2 years ago though.
Where there is a will, there is a way. I have one 24" screen horizontally, one vertically, and a third vertically on the windowsill. :p
now that what i'm thinking
don't suppose u know the dimensions of the white monitor mounts? doesn't look that big.
Only need something as big as that area.
like I said i have 110cm from wardrobe to wall but as far back this way as I reall need
