Triple Rad Case
11 Dec 2007
Rochestet, Kent
I might be in the market for something a bit stylish.
I like the look of the Fractal cases, some Lian Li's and the Antec P183/193.
But are there any that can take a triple rad without being externa? and hopefully without much modding?
You dont sat what your budget is, but I would suggest either Silverstone TJ7 or Coolermaster ATCS 840 - both will take a tripple rad ok and maybe even a quad depending on size.
Hope this helps
Mark
edit: tj07 defo takes a quad radiator in the bottom.
supposidly soon there should be some new fractals out which are bigger as the r2 is spose to be like the 900 and they are going on the same system as antec so they are making a 1200 style one and a 300 one some how i think
so that could be a option available
So theres not that many :)
Ill keep an eye out for those Fractal cases daniel, If I didn't have a triple rad I would have bought the R2.
