triple screen, no portrait?
20 Feb 2009
Ashton-Under-Lyne
For a while I've been using a 4870, and a USB graphics adaptor to use 3 screens, the centre monitor (Samsung T260, 26" 1920x1200) in landscape, and the side monitors (Viewsonic VX922, 19", 1280x1024) in portrait.
I recently decided to buy myself a second hand 5770, and a DP>DVI adaptor, so I can run all the screens off the gfx card, rather than the USB adaptor. I just got it all plugged in today, but once all 3 screens are plugged in, the option to rotate any monitors disappears.
Is there any way to change this, so I can get my side monitors in portrait mode again?
Forgot about that, but just tried it, and it doesn't do anything, even when I only have 2 monitors plugged in, and I can change the orientation through ccc...
I'm not running eyefinity though, what card are you using kylew? could be that the 5000 series don't support it, but 6000 does or something? Also, are you using the latest drivers?
