Triple Screen Workspace
6 Feb 2011
At your mums
Hi
I had a dual screen setup in my living room on a standard computer desk, however due to a new arrival in the family we now have a lack of space so I have had to take down my beloved computer desk :(
I obvioulsly need to get my pc up and running again asap, so here are my thoughts.
We have a large dining room table which is located next to a blank wall. I want to wall mount 3 monitors on this wall, have my desktop in a small unit in the corner of the room (nice and tidy :D). I can run cable in the wall etc but my main problem is how to i mount the monitors on the wall?
1: Use 3 x wall mount brackets, but would this look messy? (my wife wont be happy if it does lol)
2: Make a bespoke cabinate of some sort to house the monitors etc?
Does anyone have any links etc to builds so I can get some ideas etc?
thanks in advance
Are you looking at buying the monitors new? Or using ones you currently have? If its the former, then as long as you get VESA compliant monitors, mounting will be neat and tidy with many different brackets available. If you already have the monitors then you would have to check to see if they are compliant or not, and if not, then yes your 'cabinet' idea may be better, though I would think a sturdy enough shelf would do the trick?
or this one that I have got:-
