Triple screens ~ £750
31 Jan 2004
Newcastle UK
Simple enough question, if you were buying 3 screens for a triple /eyefinity setup, purely for gaming (specifically at the moment iracing but will be used with others as well).
I have a budget of approximately £750 so £250 a screen.
got a GTX 680 so powering these will not be a problem.
Knock yourselves out, but please explain why you recomend a specific model please: )
Just learned something there, that the GTX 680 can support up to 4 displays.
From looking on the nVidia website, has a max resolution of 4096 x 2160 so that will be a limiting factor there with resolutions on the monitors being mostly 1920 x 1080 (1200 for 16x10 aspect)
I have 3 x Dell 2410's, but am using a 7970 to run mine. Eyefinity is only available using ATi tech AFAIK. Have used that for sim action and is very immersive (no, you don't notice the bezels. Your brain filters them out after a while)
From looking at the resolution specs above, you could feasibly have a set up of 2 wide by 2 high
I would go for these if i was you....
