tripod advice
GeX
GeX
17 Dec 2002
Manchester
after my last set of pictures didn't come out as well as i'd hoped (camera shake) - i think its time i got a decent tripod. i have a cheapy. but everytime ive used that its just wound me up as i couldn't do minor adjustments to its posistion to frame shots how i wanted them.
most important factor - it has to be as small as possible, light and very portable.
I know a chap who uses a Velbon Ultra Luxi F tripod which looks rather small when closed, but it seems decent in terms of its sturdiness and portability
I use one of those as well, very small when closed up , ultra portable, goes to pretty much flat if doing close-up bug work.
twist lock legs take a little getting used to but are reliable.
thanks guys. will pop into some stores in town and ask to have a look at one.
what are the legs like on them, my cheap tripod wasn't keen on sand getting on the legs..
coolio.
theres nothing on them that'd rust and jam if they got wet is there.. i am careful with my kit but its not always used in environments that are the best!
alexisonfire said:
<snip>
You get what you pay for with a tripod.
You do indeed.
As with most things tripods are a compromise; in this case between price, stability, weight and flexibility.
Choose the best you can afford, Velbon, Slik and Manfrotto are the brands that are usually regarded as amongst the best choices. Also, choose the heaviest that you can reasonably expect to be able to carry. Too heavy and it will be left at home, too light and you may as well leave it at home. Budget for a dedicated bag or carrying strap to make it as easy to lug around as possible.
Other features to look for are the ability to fix the head to the bottom of the column to get down really low and the possibility of fitting extra supports for off-camera flash.
You don't say what you will be using it for - for some things a monopod offers a bit more flexibility ar the expense of a bit of stability. If you choose carefully you can get a tripod and a monopod and switch the head between them as required.
The 190manfrotto is heavy and not "highly transportable" Velbon are much lighter - but remember this does mean less stable in windy conditions. The manfrotto is also capable of many more positions. But again, if it comes mostly down to weight, the velbons are a popular choice.
