- 4 Dec 2009
- Worcestershire
Hi guys,
I am trying to plan my next few purchases photography wise so this purchase may not happen for a good few months but what tripod and head would you guys recommend for between £80-150? Preferably I would like to spend around £130ish but can stretch if needed. Sturdiness is my number 1 priority followed by weight followed by compactness.
I would quite like a ball head but not one of the ones with the grips if possible. I would like carbon fibre if my budget stretches to that but I would prefer a good quality aluminium tripod (or whatever they are made from
) to less sturdy carbon fibre tripod.
If possible it would be nice for it to be able to get low to the ground as well
What do you guys recommend?
EDIT: I forgot to mention I don't mind buying 2nd hand.
