- 28 Jan 2005
- Southport
Hello all,
From a recommendation from here about 3 months ago I bought a D3100 which im having soo much fun with
Now im looking for a tripod for stability on long exposures. This may well be using for macro photography a bit later down the line to so ideally it would need to go quite low too.
I dont have a lot to spend, maybe about £40.
Ive seen this one on the bay but im not sure and I dont think it will go low for macro shots.
What do you think? What can you recommend?
Thanks
Thanks
