tripods + aeroplane
5 Jan 2004
London
Hi guys,
just quick question - can you carry a tripod in your hand luggage? Usually I put it in with checked luggage but was wondering if I could leave it in my camera bag?
Thanks
If you can easily pack it in your checked in baggage then that's what I'd do.
Simply not worth taking the risk to have it refused in your cabin baggage.
Guess it would depend on size/weight a lot but if there's any doubt you may as well check with the airline first!
Mine (Manfrotto 055CXPro3 & 410PL) goes in my hold baggage - head in a padded bag, everything in the middle surrounded by clothes.
With an average 6kg hand luggage limit, I struggle to get my lenses and bodies though as carry on.
It is not amateur of size, security won't like you taking a tripod through. My Gitzo 3535 + bh-55 is like a baseball bat, a solid steal head makes for a pretty deadly weapon.
Fr th Sam.l feeble flimsy kind you might get away with it, but then I wouldn't other with them n the first place.
I was coming back through Geneva earlier in the year and had a collapsable monopod in my hand luggage. The guy who was searching my bag took it off to the Senior Customs guy for his opinion on whether I was allowed to keep it.
Luckily they allowed me to have it back after they all had a good look, but it wasn't even a thick or heavy monopod compared to most, it only really holds my GoPro camera. So I now wouldn't put such a thing anywhere but my hold luggage. I can only assume that they might consider anything extendable like a monopod/tripod could be used as a weapon.
Well to a certain extend, it is a matter of size since if it's too big to fit in the overhead compartments they definitely wouldn't let you take it lol :)
Anyway, as mentioned here, if there is any doubt (which there seems to be!) then you're better off putting it in the main luggage or risk some numpty confiscating it or or having to sort out having it added to the luggage hold later :(
