Tripple Radiator Case?
Cheers, quite like that, shame it's in silver only on the website. When you say cut, is that inside of the case for the tubing or do you have to route it outside?
Thanks
I mean if you are going to put the radiator in the top of the case (can't see where else you would put it?) you will have to cut blowholes for the fans, like so....
There is a company called Aqua Computer that mods the G70 for you and puts their triple radiator in the roof for you. They did the PC343 Thor system that Yewen liked so much just before Christmas. It's not a bad deal either iirc. I think the standard case is about £160 and the modded one with the radiator in it is about £235. Do a google search for "AC Lian Li G70 XT Extreme Black" and you should be able to find some pictures. If you do decide to buy a G70 and hack it about yourself, the roof panels are available as spares so if you wanted to put it back to stock (or you bodged it hideously) you could just do a quick repair ;)
Silverstone TJ-07, Mountain mods UFO. 2 cases I am considering to house a PA 120.3. Neither will need modding. TJ-07 for the 'posh' folk - MM for the in ** face look :)
my thermaltake armour would fit a 3 fan rad down the front.
so would a CM stacker the old version its one bay taller than the thermaltake armour.
i have 3 fans down the front of my thermaltake armour and allso have 2 bays left (dvd drive) and a empty one :)
i was thinking about water cooling mine. cause i just have 3 fans blowing air it no water at the moment
I like the Cooler Master, and the SilverStone, and the friggin Lian.
What set me of on a new case though was another post on this forum. The Windy Black Knight - All set to mod my old Eclipse etc. but after seeing that.... makes the Akasa look a bit cheapish.
I wish the Akasa had an aluminium front and room for at least a double radiator.
SilverStone a close second though.
But aquacomputer stuff sucks more than the cast of captain pugwash :o
You're much better off going to a watercooling or modding related store if you want it cut for you, and get a thermochill PA120.3 radiator with 5v or 7v yate-loons all round :)
Why not buy a swiftech radbox and mount the rad on the outside,im doing this with a thermochill 120.2 on my case,no need for any cutting. :D
