12 Apr 2016 at 22:08 #1 oll3h oll3h Associate Joined 23 Oct 2012 Posts 405 So my Triton AIO Water Cooling Solution is due to be topped off as (hopefully) there's been some evaporation. What exactly do i need to buy to refill it and where can i get it?
12 Apr 2016 at 22:34 #2 Kelt Kelt Soldato Joined 14 Nov 2007 Posts 20,217 Location In the Land of Grey and Pink De-ionised water, available from loads of places.
12 Apr 2016 at 22:39 #3 oll3h oll3h Associate OP Joined 23 Oct 2012 Posts 405 Can i just use this then? http://groceries.asda.com/asda-webstore/landing/home.shtml#!product/479358
12 Apr 2016 at 22:40 #4 Kelt Kelt Soldato Joined 14 Nov 2007 Posts 20,217 Location In the Land of Grey and Pink oll3h said: Can i just use this then? http://groceries.asda.com/asda-webstore/landing/home.shtml#!product/479358 Click to expand... Yup.
13 Apr 2016 at 10:42 #6 Kelt Kelt Soldato Joined 14 Nov 2007 Posts 20,217 Location In the Land of Grey and Pink oll3h said: Thanks for the help Click to expand... You're welcome. If you didn't know, Raijintek recommend not to fill the reservoir above the first "crease".
19 Apr 2016 at 12:12 #7 liveforeva liveforeva Associate Joined 23 Aug 2006 Posts 264 Location North Wales I need to refill mine Could I use just normal coolants that you can buy from here such as https://www.overclockers.co.uk/mayhems-ice-dragon-nano-fluid-1l-wc-031-mh.html
19 Apr 2016 at 13:01 #8 Angst Angst Soldato Joined 26 Nov 2008 Posts 4,266 Location Leeds Isnt de ionised known to cause corrosion in copper etc as it takes back ions from the copper over time or something.
