I've set up my static i.p etc, just need to find the settings so I can enable the DMZ. I read you could do this through a web browser but I tried this (through my ps3) and it didn't work. Can changing the settings for the router only be done through a PC browser? Does it have to be the host PC? Or is changing settings via web browser an option only available to 'linksys' routers?
If so then how would I change my settings? Using a edimax Br-6226n router if it helps.
