27 Feb 2006 at 09:13 #1 IceAx IceAx Soldato Joined 4 Aug 2003 Posts 5,852 Location Warrington Hey peeps as above! Im struggling to find drivers / setup for a Buffalo WMR - G54 Have tried the usual, can anybody suggest any more options? Cheers Andy
27 Feb 2006 at 10:34 #2 Wyvern971 Wyvern971 Associate Joined 6 Oct 2004 Posts 1,921 Location London www.driverguide.com EDIT: nm they didn't sem to have them either And by doing a google search it seems the WMR 54G is a an ADSL router. Usually this is done by logging into the web interface of the router. (you shouldn't need drivers) find out what your ip is (by opening a command prompt (Start->Run type CMD and press enter)) type "ipconfig" without quotes try x.x.x.1 (where x are the first digits of your IP) use default username / password You may want to disable any firewall software while doing this (as it can interfere as I found to happen with the Netgear I had) Last edited: 27 Feb 2006
27 Feb 2006 at 10:38 #3 IceAx IceAx Soldato OP Joined 4 Aug 2003 Posts 5,852 Location Warrington No cant find them on there either Andy
27 Feb 2006 at 10:44 #4 Wyvern971 Wyvern971 Associate Joined 6 Oct 2004 Posts 1,921 Location London Edited my post above (if it's not an ADSL router what device is it?)
27 Feb 2006 at 11:42 #5 IceAx IceAx Soldato OP Joined 4 Aug 2003 Posts 5,852 Location Warrington It is as above mate, just wanted the disk etc to make life easier! It was for my old man, but sod it ill set it up for him Cheers Andy
