trouble getting MEGARaid installed on Fedora 14.
10 Nov 2004
Expat in Singapore
Hi,
I have a dell Perc 6/i I cannot get in to the BIOS of. I am now trying to access it via the LSI software (megaraid) downloaded from their site.
When I come to install I am getting this error;
Code:
[root@Nas disk]# ./install.sh -a
Starting complete installation of MegaRAID Storage Manager 2.92-02....
Checking for any Old Version
Patch Sequence 1.0.0.0 for MegaRAID_Storage_Manager 3.0.00 not found
No Old Version Found
Continuing with installation
Installing  MegaRAID_Storage_Manager-2.92-02
Preparing...                ########################################### [100%]
Installing....
   1:MegaRAID_Storage_Manage########################################### [100%]
Starting Framework:
Starting Monitor: /
./popup_bin: error while loading shared libraries: libpng12.so.0: cannot open shared object file: No such file or directory
set: KEY=INSTALLER_VERSION   VAL=v2.92-02
error: Failed dependencies:
    libstdc++.so.5 is needed by sas_snmp-3.16-1007.i386
    libstdc++.so.5(CXXABI_1.2) is needed by sas_snmp-3.16-1007.i386
    libstdc++.so.5(GLIBCPP_3.2) is needed by sas_snmp-3.16-1007.i386
SAS SNMP installation failed
    libstdc++.so.5 is needed by sas_ir_snmp-3.16-1010.i386
    libstdc++.so.5(CXXABI_1.2) is needed by sas_ir_snmp-3.16-1010.i386
    libstdc++.so.5(GLIBCPP_3.2) is needed by sas_ir_snmp-3.16-1010.i386
SAS-IR SNMP installation failed
[root@Nas disk]#
I also get the following popping up from time to time.
Code:
I have been searching around trying to install the missing dependencies but just do not be able to find what is required.
Any suggestions please ?
Thanks
RB
To start you off:
32bit : http://pkgs.org/fedora-14/fedora-i386/libpng-1.2.44-1.fc14.i686.rpm.html
64bit : http://pkgs.org/fedora-14/fedora-x86_64/libpng-1.2.44-1.fc14.x86_64.rpm.html
This should fulfil the libpng12.so.0 error. You are probably best installing it through fedoras built in package manager. Search for libpng.
I believe if this doesn't work then it means that the files in megaRAID storage manager have been statically linked and point to somewhere other than where fedora stores libraries (i think...).
EDIT: For the second set of errors I would install:
yum install compat-libstdc++-33
while you're at it you may as well do them both at once:
yum install compat-libstdc++-33 libpng
