Trouble MW2 Crossfire Anyone??
Are you using 10.6 drivers? also try disabling vsync and see if it still does it if your using vsync (no self respecting fps player should :P)
Yes i do use v-sync, im one of those people who have to have games looking the best they can.
My GTX295 use to microstutter a lot on some maps as well, but not as bad as the 5870s!
I will try turning it off.
Make sure you use the crossfire profile update for 10.6 if your using them as this solves a few related issues.
