- 7 Aug 2004
Hi all, I previously had this setup:
Dell 30" 3008WFP via DP
2x 27" via DVI-D
And it all worked fine at the max res at 60hrz and I could play HDCP content no problems.
Now I have:
Phillips 40" via DP
Dell 30" via DVI-D
DGM 27" via DVI-D
And now all of a sudden I can't play my amazon prime video in HD - saying I dont have HDCP compliant screens
Right this second im only running the philips and dell monitor as bizarelly the DVI-D cable I used on the no longer used 27" screen won't work properly on the dell - gets garbled interlaced screen & the ONLY DVI-D cable that will work is the one that used to be in the DGM monitor..................
I have ordered a new DVI-D cable to come tomorrow for the currently unused DGM screen.......but I am assuming the Dell on the DVI-D cable isn't HDCP compliant
I am using 2x r290x graphics cards in crossfire - so the ONLY available outputs I have are:
DP
2x DVI-D
HDMI
I am aware I could disable crossfire and use 2 DP's out from them but obviously I dont want to do that.
I also tried using the HDMI out to the DELL, but it wouldnt work above 1920x1080.
I then tried DVI-D out to monitor HDMI, no go, then tried hdmi out to DVI-D on the monitor again only 1920x1080
SO - ANY IDEAS ANYONE ? doing me nut in.
2x 27" via DVI-D
Now I have:
Phillips 40" via DP
Dell 30" via DVI-D
DGM 27" via DVI-D
DP
2x DVI-D
HDMI
