Trouble with MSN Live! File is unsafe to view
Caporegime
8 Sep 2005
Norrbotten, Sweden.
THis is really getting on my wick, ive googled about it and tried a few other forums.
After downloading files it tells me they are a potential risk and wont allow me to open them
I have Avarst! setup as my virus checker and it scans every blooming file i receive from trusted sources.
Is there anyway short of going back to MSM7 that i can delete this extremley over cautious security settings.
Also how do i get the hand wrotting feature to work???
many thanks in advance,
Jeff.
So you want to disable the MSN "Ooh you sure you wanna download that pet?" safety feature?
Download the Mess.be or A-Patch. Both have similar options to allow you to remove stuff you don't want for MSN and mod it a bit. Both allow you to disable that feature.
I used to use the Mess.be patch but I then discovered A-Patch and use that nowadays.
As for the handwrotting ( :rolleyes: ) feature I think you need to install the Windows Journal Viewer AND not disable the handwrotting ( :p ) feature in Mess.be or A-Patch.
lol i was speed typing and my boss walked into the office so forget to check what i had typed before i hit send.
thanks mate. :D
A-patch
all i had was 40ish check boxes none relating to security stuff.. ill try again tommorow
cheers :)
Efour2 said:
A-patch
cheers :)
Run A-Patch again. Check each page very carefully, one of them has a disable file sharing protection option or similar. I can't remember which page or what exactly it is called but it is in there. I can't run A-Patch now as I am on MSN.
Check it again, it is in there somewhere.
