Hi, I started building my first PC but have ran into a problem, I did the assembly and set the bios to boot from CD, got to the windows region and language selection but about 30 seconds into the install the animated aero cursor freezes and I cannot move it with the mouse, the sytem seems to freezer and I cant get any further. I am upgrading from a Pentium 4 to an AMD 955, the system is entirely new apart from the PSU and the HDD. The HDD is from my old machine and still has the old Win 7 operating system that I had with my p4, could this be a problem as I am now using a different chipset ? Should I really start with a pre-formatted HDD incase its something to do with the different processor info on the drive ?
Also my old PSU is a 405watt Jeantech unit, could it be lack of power ?
The rest of my spec is as follows:
AMD Phenom II 955 be
ASUS M4A785TD-V EVO
4 GB OCZ Platinum pc3-12800 4GB DDR3 ram (OCZ3P16004GK) is this definately AMD compatible ?
1 x CD drive
1x sata HDD drive
Im using the onboard card.
Ive got the RAM plugged into DIMM A1 and B1 if that makes a difference ?
Any help in getting my system up and running would be great, Thanks in advance.
Noob in distress.
ASUS M4A785TD-V EVO
1 x CD drive
1x sata HDD drive
Noob in distress.
