- 11 Oct 2007
Hello,
I have the following set up...
Q6600 G0 Revision CPU
P35 Dq6 F6 BIOS Mobo
2GB PC8500 Crucial Ballistix RAM
Thermalright Ultra Extreme with 120mm fan on it
850 ocz power supply
I managed to overclock my system and get it be ORTHOS stable, the problem i have is that when i shut down my PC and then try to do a cold boot it hangs on memory testing and reboots itself back to the default BIOS settings. The memory proved to be fine when running memtest and is not overclocked. I changed the voltage from the BIOS to +4 as well and changed the compatibility option to number 2.
Anyone can help?
Anyone can help?
