Trouble with periodic fps drops while gaming.
2 Nov 2015
Hi there I am having issues with my fps drops in certain games like Witcher 3, GTA V and just cause 3 all large open areas; once every 10-20 seconds my frame-rate halves (usually 60 down to 30) and the game really chugs for a couple of seconds then is fine again, this is only started happening really recently which seems like it shouldn't be considering I have a 1080. I also think my PC seems generally slower loading tasks but can't really be that certain as I am not great at judging these things.
I have run memtest for 4 passes with no errors both my GPU and CPU seem to stay in very health temp ranges (nothing over 70)
I thought this could be a SSD issue but my Sandisk ultra II appears in ok health from the crystal mark run and the sandisk dash but I am not great at knowing if thats an ok score or not.
CrystalDiskMark 5.2.1 x64 (C) 2007-2017 hiyohiyo
Crystal Dew World : http://crystalmark.info/
* MB/s = 1,000,000 bytes/s [SATA/600 = 600,000,000 bytes/s]
* KB = 1000 bytes, KiB = 1024 bytes
Sequential Read (Q= 32,T= 1) : 557.653 MB/s
Sequential Write (Q= 32,T= 1) : 344.744 MB/s
Random Read 4KiB (Q= 32,T= 1) : 383.128 MB/s [ 93537.1 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 187.393 MB/s [ 45750.2 IOPS]
Sequential Read (T= 1) : 382.470 MB/s
Sequential Write (T= 1) : 364.437 MB/s
Random Read 4KiB (Q= 1,T= 1) : 41.304 MB/s [ 10084.0 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 149.529 MB/s [ 36506.1 IOPS]
Test : 1024 MiB [C: 85.6% (764.5/893.6 GiB)] (x5) [Interval=5 sec]
Date : 2017/03/08 10:45:30
OS : Windows 10 [10.0 Build 14393] (x64)
Would very much appreciate any advice for finding the issue.
specs are i7 4970k, 16 gb, of hyper x ddr3 ram, a palit 1080 game rock and a coursair hx750 psu. Also fire strike benchmarks for my pc are fine at 18,000 which is consistant with how its been since i got the new card.
The drop from 60 to 30 every now and then sounds like Vsync is on, whether in-game or in Nvidia Control Panel. Can you check that?
Okay try disabling it, see what happens. If all good and you like some sync, try enabling Adaptive Vsync for each game in Nvidia Control Panel (leave game vsync off) to see whether that's smoother. I know Adaptive Vsync in Nvidia Panel works better for GTA. Let us know.
Doesn't seemed to have made a difference but i just checked my event log and its getting different errors
1- There was insufficient disk space on volume \\?\Volume{87d9011e-3449-46b7-91de-c9f2b2d6c654} to create the shadow copy of volume C:. Shadow copy storage creation failed.
2-A corruption was discovered in the file system structure on volume C:.
A corruption was found in a file system index structure. The file reference number is 0x9000000006531. The name of the file is "\ProgramData\NVIDIA Corporation\nvstreamsvc". The corrupted index attribute is ":$I30:$INDEX_ALLOCATION".
3-A corruption was discovered in the file system structure on volume C:.
A file on the volume is no longer reachable from its parent directory. The parent file reference number is 0x9000000006531. The name of the parent directory is "\ProgramData\NVIDIA Corporation\nvstreamsvc". The parent index attribute is ":$I30:$INDEX_ALLOCATION". The file reference number of the file that needs to be reconnected is 0x1ea00000000027c. There may be additional files on the volume that also need to be reconnected to this parent directory.
4-The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
{8D8F4F83-3594-4F07-8369-FC3C3CAE4919}
and APPID
{F72671A9-012C-4725-9D2F-2A4D32D65169}
to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
seems to be something up with C: drive
