Hi
I wonder if anyone can give me any advice. My daughter decided to clean out the dust from her PC. She only removed the side panel and used a very soft artists brush (everything was disconnected from the electricity). When she thought she had removed sufficient "fluff" to allow the fans to work again, we plugged it back in. It now boots the PC from the on switch at the back on the PSU instead of allowing you to press the usual on button at the back. There is also nothing on the screen although all the fans etc.. are going round. Could there be some dust or fluff somewhere causing this? Thank you, Sue
