Trouble with very basic Javascript exercise
Code:
var WEIGHT_KEY = 'weight';
var person = {
  weight: 350
var weight = person[WEIGHT_KEY];
If you want to refer to the property of the object defined by WEIGHT_KEY, you have to it it using bracket notation ([]). Using dot notation assumes that you are actually providing the name of the property, not a variable referring to it.
Also the actual property in the object, WEIGHT_KEY, was incorrectly named. It should be weight. The reason is that the example says suggests that WEIGHT_KEY refers to the property of the object, in this case the 'weight' property.
Hope I explained that ok. :)
