Troubleshoot a problem for me
13 Dec 2002
Manchester City Centre
I have a slightly worrying, highly annoying problem with my mk3 Golf gti 8v, randomly it will struggle to keep sufficient revs to prevent the engine from cutting out, this can be while idling, or it can be while driving along.
If idling it will either cut out or practically stop (<500 revs) and then manage to start itself again. While driving it seems to be primarily while turning a corner, and can seem like I'm in too high a gear (when I'm not), or the rev counter can just plummet and the motion of the car essentially bump starts itself.
Both of these are very intermittent, I'd experienced both maybe twice randomly in the past 3/4 months, but both have happened a couple of times this week, still very intermittent in terms of I've probably made 20 journeys without anything happening, but it's enough to want me to get it sorted before I do some (more) damage to the car.
I'll be taking it in to the garage tomorrow but would like a decent idea of what it could be. The only suggestions I've had so far are the fuel filter (meant to check whether this was replaced at the last service) or head gasket. Any help will be much appreciated.
had it in the garage yesterday, they immediately said it was a common problem on that mk of golf to get the throttle assembly clogged up, so they took it apart and cleaned it up, said it was caked in crap. Charged an hours labour and no parts.
Hasn't fixed the problem :(
Going to ring and let them know today and get it booked in for next week as I need it over the weekend.
You say it happens when turning? Checked the power steering fluid at all?
First thing I checked. Looking into it I think the heavy steering thing is likely to be unconnected, likely to be a worn power steering belt.
im a mk3 golf geek, you should look at the things i posted before you throw more money at dodgy garages again
:confused:
You posted one thing I could check, which didn't appear to be wrong, and one thing that would need diagnostics to check.
On my model with the AGG engine the lack of an ICV means that the clogged throttle body can cause idling problems. It was a sensible first thing to try, and as it's a very intermittent problem the garage couldn't confirm it to be fixed or not. Not sure how that makes them dodgy, or me throwing money at them?
sorry if i rubbed you up the wrong way there.
sorry again, but having worked on countless AGGs, loads with idle and cutting out issues, none have ever been cured by cleaning the tb. it just doesnt happen. in fact, excess crud on the tb is an indicator that the breather system is in fact broken as all that crud is being carried through by the airflow that is drawn in through the leak.
did the garage do diagnosis on the ECU and if so did they tell you anything about fault codes?
They didn't, they'd misunderstood the problem, thought it was just when sat at idle. They're going to have it on monday for enough of a drive to experience the problem first hand.
if it is a crank sensor, the ecu will keep a log of that problem occuring, "g62 crank sensor implausible" or something along those lines, but im sure they know about all that sort of thing
You get an e-cookie, it was the cabling to the crank sensor, had worn through, and occaisionally when jolted would flash as a fault on the crank sensor and kill the engine. All fixed now.
