- 21 Oct 2002
- Maidenhead
Hi all. I have a vexing problem and I’d appreciate your thoughts.
Relevant specs (no overclocking or anything):
There is one way in which I can make the PC boot reliably. When the PC becomes unresponsive, I hold the power button until it shuts off, and then I flick the switch on the PSU to ‘off’. When I then press the PC power button, the PC shows a flicker of life but then dies (because the PSU is off). When I then flick the switch on the PSU to ‘on’, the PC boots normally without me pressing the PC power button.
I’ve rebuilt the PC in a new case (Fractal Design Refine R4), not to solve the problem but because I needed a new case, but nevertheless this didn’t make any difference. I’ve also invested in a PSU checker, which didn’t find any problems with the PSU, and the PSU is adequately powered for my rig I think. Finally, I’ve tried stripping the PC down to minimal components but the problem still happened.
Sorry for the long message! So my questions are:
Ginga
- Mobo: Gigabyte GA-EX58-UD3R (socket 1366)
- CPU: i7 920 (at stock)
- Cooler: Titan Fenrir
- RAM: Patriot Viper – 3x 2GB
- GPU: Nvidia 770 GTX
- SSD: Crucial 240 GB
- PSU: PC Power and Cooling 910W (80+ silver)
- Any thoughts as to the likely cause?
- If this were your rig, what component(s) would you replace, in an attempt to fix the problem?
Ginga
