I have a 55 plate Seat Ibiza 1.4 16v petrol and I'm noticing that when I put my foot down in the lower rev range especially the car will jerk/hesitate occasionally through the lower rev range until it reaches about 2-3k and when it seems to get better.
It doesn’t feel like normal engine strain because the acceleration is lumpy when you're putting your foot down for some extra power (when rolling in second for example and pulling out at a roundabout). Last week I had one incident when the engine started to idle strangely, when at a stop the car was shaking more than it should do and the revs were jumping about between 700-900rpm when it’s usually constant at 700 or so when warm, the engine seemed to lack power also. After stopping the car and opening the bonnet the engine seemed to be physically wobbling and I decided to stop and start it and the rough idle seemed to go away.
No warning lights on the dash so...could any of you shed any light on what it could be?
