Hi,
I'm trying to figure out what's going on with my mate's PC. He says that it regularly crashes and makes a 'horrible sound'. From my testing I think this is the CPU overheat alarm from the BIOS. I ran Prime 95 on it and when running the 'blend; test it stops on the first iteration with a error. If I run it on 'Small FFTs', it seems to run for about 5 minutes before the PC crashes with the bios alarm.
Wierd thing is that MBM shows the CPU temps to have risen from 39 to about 48 when it crashes which doesn't seem that high to me. Just in case I cleaned the thermal compound from the CPU and reseated the HSF and ran it again. This bought the idle temps down a bit but it still crashed at about the same temp. There is no CPU temperature limit set in the bios.
Can anyone suggest what the problem might be? I'm wondering if the CPU might be dying since it has been running fine for 3 years up until this. Or could it be a power issue? The PSU is just the one which came with the case so it's nothing special but then it's worked fine up until now
Spec is
AMD Athlon Barton 3200+
Abit NF7-S2 Mobo
2 x 256MB PC3200
NVidia FX5200
Cheers
Spec is
Abit NF7-S2 Mobo
2 x 256MB PC3200
NVidia FX5200
Cheers
