I got said CPU a couple of weeks ago along with an Asus X99 A-II motherboard and OC'd it to 4.4ghz @ 1.25v. After about an hour of Realbench everything was fine and i've done some Aida64 tests that were also fine as well as Heaven whilst tweaking my GPU OC. I haven't had the time to game much but recently re-installed Skyrim with the intention of modding it heavily.
After playing Skyrim for about 10 minutes my PC reset itself which was rather alarming and initially i thought it was my GPU OC' so i backed it off and tried again. Again after about 10 minutes in Skyrim the screen went black and became unresponsive so had to turn the system off completely. When booting back up i got a message in POST saying my overclock had failed and I need to enter the UEFI and sort things out. I do so and reduced the clocks to 4.2ghz but still it crashes in Skyrim after 10 minutes or so but not after 30 minutes of Realbench. In the end i went back in to the UEFI and reset to system defaults and now Skyrim is fine with no crashing.
The troubling part is that when it crashes in Skyrim Riva OSD is only showing about 13-20% CPU load with temps of 60c and yet it's stable in RealBench with 100% load.
I'm really confused and since im a noob OC'er I really dont know how to troubleshoot the problem. FWIW I did not enable XMP and my PSU is an EVGA G2 850W that powered my previous system faultlessly.
