Truck simulator build?
6 Aug 2015
Scotland
Hey
I am building a PC to play the truck simulator games have been trying to spec out one and just wanted a little hand with what to do please?
I have around £500 or so and if I could get something that could possibly be upgraded in the future that would be brilliant thanks
Hey
Do you have a PC at the moment? If so what spec?
What res do you game at as well?
If you are starting from scratch and buying new then forget it as £500 simply isn't enough. Anything you buy brand new for £500 is going to leave you very disappointed. You should be able to manage something half decent although older second hand but you are restricteds to what you can pick up on Ebay or Faceebook marketplace and that's a minefield. Do you have a monitor and keyboard/mouse because if not you are going to struggle even going second hand. Personally I would want to double your budget for a decent gaming experience if buying new and probably £700 if buying second hand and you need a monitor and keyboard/mouse as well
I have over 1200 hours in ATS/ETS2 and gaming at 1440p I was running out of vram in places (using mods) with a 8Gb RTX3070 so had to upgrade to my current RX7900GRE 16Gb card and that alone is more than your entire budget. Forget the minimum and recommended specs, a 2Gb gpu is not going to cut it and any gaming experience is going to be a miserable experience that will leave you wondering why you have spent all this money to have it looking so bad. Once you try mods from the workshop you are going to want more and if you use any graphics mods they are going to hit a gpu hard. You are going to need a M2 drive as well as it smooths out loading in game.
Looking ahead, a decent wheel and pedal set makes for a much more enjoyable gaming experience as well. Taking it further a shifter (I have a SKRT truck shifter) adds to the realism but all of this costs a lot of extra money. Yes, you can play with a controller but it's nowhere near as enjoyable.
Truck sim in not very demanding, i play and love the game but £500 for a new build is tight. if you went used i say it can be done for the tower only.
i think a RTX 3070/RX6700xt can handle this game paired with a 5600x/12400
the problem with PC's just like consoles everything get more expensive, i made my neighbor a PC a few years ago for £600 that same pc now would be £800
this is not a spec i feel you should buy but a collaetion of the chepest parts on OcUK i feel would play the game
My basket at OcUK:
Total: £578.93 (includes delivery: £0.00)​
Like he said, please do not buy that lot. Outdated tech with a poor psu at new prices is way more than that is worth. I wouldn't even buy most of that used. It is also rarely advisable to pick the cheapest of everything as there are too many compromises and it will bite you in the butt sooner or later. The game can be quite demanding when adding in some of the many free mods from the workshop, especially the graphics and weather ones. Like I said, I had problems with a 8Gb 3070 running out of vram when running these games.
