True 120 tightening.
Caporegime
3 Jan 2006
Chadderton, Oldham
Hi.
Just wondering if it is possible to overtighten the 4 screws and this end up in reducing the cooling performance?
Thanks
Will.
Well it is on and has being for a long time now, just wondered if you can have it too tight where it pushed against the CPU too much and causes the thermal paste to thin out too much?
No, the tighter the better.
I actually have a 2p coin between the bracket and the top of the TRUE base so it gives extra pressure.
Like this:
I've used the spongy disc that you get in some CD/DVD spindles under my mounting bracket and I kept on turning till the screws bottomed out, that's what you're supposed to do AFAIK.
May try a 2p or washer on mine, as even after lapping the cpu and cooler i still get a bit of a temperaure variation on mine between the 2 sets of cores.
Reason I did it to mine, I had 5c variation on 2 cores, added the 2p coin and I only have 3c variation now :)
This is how mine are at the minute.
4'c between 0 and 1 and 4 between 2 and 3, each individual pair of cores when placed under 100% load tighten up to 68-68-62-62, thats with the cpu and TRUE lapped.
May I ask the vcore your running for 3.8 GHz on air, been sat at 3.6GHz for ages and never tried any higher, however since I now have a TRUE and temps are better; might attempt 3.7 and see how things go (Currently 1.4v BIOS, CPU-Z 1.380). Not had the time of late to stress test in length since replacing the Scythe Infinity.
Oh and that washer idea is a winner, will give that try at some point.
Vcore in bios of 1.50625, windows idle 1.500v, prime95 load, 1.512v. also ran mine for a while at 3.6ghz with 1.4v.
washers are easier to ensure that you keep the pressure even because the little screw thing on the X braket can sit in the hole thats on the top side of the heatsink base
