True HD audio Blu-Ray player software
16 Jan 2003
by my pc. :D
Hi,
I'm using WinDVD9 and it has come to light that it seems to downsample high quality audio tracks to 48khz/16bit audio regardless of the hardware its running on.
I was watching the incredible hulk the other night and noted that even though its a 48khz/24bit Dolby audio track/stream, its output is 16bit. This is the information it provides itself in the information page of the settings section. I've ticked the "allow 98khz/24bit audio support" option but its still downscaling.
Is there any software out there which allows proper support of high def audio on compatible audio hardware?
I even tried using a different sound card instead of the onboard audio on my Asus P5Q deluxe but its the same with that.
Thanks.
Well at the moment I don't think there is, there's only three bits of software that I know of that plays back hi-def discs, you're running one of them already & the other 2 are
PowerDVD Ultra (7.3 or 8)
Arcsoft total media theatre (thinking of buying due to it being able to integrate into Vista media Centre)
IMO I would wait for now, someone will include this feature sooner or later if the yank HPTC owners shout loudly enough. :D
