TRUE installation
10 Jun 2003
Just fitted a TRUE to my i7 940 on a Rampage Extreme 2 with the 1366 bolt through kit and was wondering, do I tighten the spring loaded screws up as for as they will go ? Or just enough to secure everything (both sides tightened the same amount of turns) ?
Just a bit concerned that I may damage the motherboard if I tighten them up too much ?
