Trustable review site for 4080s?
28 Aug 2013
The wife has signed off on me getting a new 4080 & I was wondering whether there was a trustworthy site with decent reviews? I used to use Tomshardware but they seem to have stopped doing their individual reviews at some point over the last decade or two.
I just bought a Founders 4080, upgrading from a 2080ti. The performance increase is noticeable, temperatures are MUCH lower and the thing boosts high with no overclock applied. Other opinions may vary, but depending on your upgrade path I doubt you will be disappointed
Massive review database here.
Guru3D and Techpowerup are the one's I normally go to so points to those two
TPU tested the 4090 with a 5800X so its review was flawed as that CPU will bottleneck the 4090 even at 4k in some games.
Didn't know that, will keep an eye out for the system specs more in future so thanks Jox!
They retested with the 5800X3D and gained 7% even at 4k over the 5800X
Then they tested with the 5800X3D with the 13900k and gained another 1.3% but they never updated the GPU database to show this and its why the 4090 appears 7-8% slower on there that what it really is.
saw that which was different, then go for individual reviews from there...tbf, most are ok, as all were built with massive over the top coolers as they all thought the 4090 would be 600+w power use, and a lot of 4080 cards use 4090 coolers also as plenty spare and economies of scale in building...so they should all run cool and quiet then
Yeah 4k.
This site takes an average of multiple reviews.
Thanks mate.
Same for me.
If you look at the 4070 review he's using a 13900. So the relative performance tables are more accurate in the review.
