Try to model a RAM memory but got some problems
24 Oct 2017
Hello, I am trying to model a 0.125GB RAM memory in Verilog using ModelSim of width 512 bit using memory chips of width 32 bit. So I have created a 32 * \218" whose code is as follows:
Code:
    //The 32x2**18 MEMORY CHIP
     module mini_sub_chip (word_out, word_in, word_addr, cs, we, clk);
        parameter WIDTH = 32,
                  DEPTH = 1 << 18,
                  SEL_BITS = 18;
    //output
      output reg [WIDTH-1:0] word_out;
    //inputs
      input [WIDTH-1:0] word_in;
      input [SEL_BITS-1:0] word_addr;
      input cs, we, clk;
    //regs
      reg [WIDTH-1:0] schip [0:DEPTH-1];
      always @ (posedge clk)
      begin
       if (cs)
        begin
         if (we)
          begin
          schip[word_addr] <= word_in;    // write into memory
          word_out <= word_in;
          end
        else
         begin
         word_out <= schip[word_addr];    //read from memory
        end
      end
    end
  endmodule
I then tried to increase the memory width to 512 by creating 16 instances of the above module in a different module as follows:
Code:
     begin
      if (reset)
       count <= 4'b0000;
      else
       count <= count + 1;
       word_output <= word_out[count] //word_output is the 32 bit output register
     end
     decode_4x16 dcd416 (sel, count);
     generate
     for (i = 0; i <= 15; i = i + 1)
     begin: loop
     assign chip_sel[i] = cs & sel[i];
     mini_sub_chip mschip (word_out[i], word_in, word_addr, chip_sel[i], we, clk); //Instantiating 16 modules in parallel
     //word_out is 32x16 array, with a different 32 bit array element driven every time 'mini_sub_chip' is instantiated
     end
     endgenerate
At every clock cycle, a 32-bit data is transferred from every instantiated module in a consequtive manner such that it takes 16 clock cycles to complete the 512-bit data transfer.
The first module is working correctly, but the second module is not. Data is being written to and read from memory correctly at every clock cycle, but the 'word_output' register is not getting updated as long as memory write is taking place. So it remains undefined for as long as 'we' is asserted. However, it is getting updated during memory reads. Please give me some advice!Thanks!
