Hi, I own this laptop:
http://www.msimobile.com/level3_productpage.aspx?id=311
his graphic card is this one:
NVIDIA® GeForce® GTX 560M discrete graphics (DDR5 1.5GB VRAM)
It's only supposed to support 2 monitors, through his outputs VGA and HDMI. It only supports 2, as i've tried to use 2 external monitors through these outputs + the laptop's monitor, but it doesn't work. It only displays on 2.
As I need to connect at least 3 external monitors to this laptop, do you know if there's any device/adapter/anything that will allow me to make 3+ monitors to work? I case there is, I need to keep the 1920 x 1080 resolution.
Thanks.
Thanks.
