Trying to connect front case audio ports to Audigy 2 ZS
16 Dec 2003
I've been trying to look for a guide on how to connect my front audio ports on my PC case to my Audigy 2 ZS but with no success so far :(
I came across this website that states the pin layout for the white connector on the soundcard. Looking at the audio port wires from the PC case, the letters on the individual wires does not match the ones in the diagram. I have the following individual wires:
Min-in (orange wire)
Mic-power (red wire)
L-out (purple wire)
L-ret (white wire, attached to L-out wire)
R-out (blue wire)
R-ret (yellow wire, attached to R-out wire)
Ground
Can anyone help me out please? :)
Has anyone here has success connecting their front audio ports to their Audigy soundcards? :o
The majority of the PC cases you can buy now comes with USB/Firewire ports and some come with audio (headphones and microphone) ports like mine :p
I'd like to connect the front case audio ports to my Audigy because I don't use onboard sound (which port wires are actually configured for) and it would be easier using the front audio case ports rather than the ones at the back of the case wouldn't it? :)
ok i get it now...just seems a lot more work then just plugging it in the audigy :confused:
