Trying to display a hidden option in javascript
22 Aug 2010
In My Command Center
hi i have three radio buttons on a form and i want the form to reveal a hidden element when one on the buttons are selected.
Code:
<tr> <!-- these are the buttons -->
                <td class="form" width="230" valign="top" align="right">Fuel Type: </td>
                <td width="503" valign="top" align="left">
                	<input type="radio" name="fuelType" id="fuel1" value="Natural Gas" />
                 	<label for="fuel1">Natural Gas</label>
              		<input type="radio" name="fuelType" id="fuel2" value="LPG" />
                 	<label for="fuel2">LPG</label>
              		<input type="radio" name="fuelType" id="fuel3" value="Oil" />
                 	<label for="fuel3">Oil</label>
            	</td>
            </tr>   <!-- the next three <tr> are the hidden options -->
            <tr id="bmgas">
    			<td width="230" valign="top" align="right">Boiler manufacturer: </td>
                    <select name="gas" id="gas" >
                 		<option value="0">Natural Gas</option>
                 		<option value="Alpha Boilers">Alpha Boilers</option>
                 		<option value="Ariston">Ariston</option>
                 		<option value="Baxi">Baxi</option>
                 		<option value="Biasi">Biasi</option>
                 		<option value="Broag">Broag</option>
                 		<option value="Ferroli">Ferroli</option>
                 		<option value="Glowworm">Glowworm</option>
                 		<option value="Halstead Heating">Halstead Heating</option>
                 		<option value="Ideal Boilers">Ideal Boilers</option>
                 		<option value="Ikon">Ikon</option>
                 		<option value="Jaguar">Jaguar</option>
                 		<option value="Johnson &amp; Starlay">Johnson &amp; Starlay</option>
                 		<option value="Keston Boilers">Keston Boilers</option>
                		<option value="Potterton">Potterton</option>
                 		<option value="Range Powermax">Range Powermax</option>
                 		<option value="Raven Heat">Raven Heat</option>
                 		<option value="Vaillant">Vaillant</option>
                 		<option value="Viessmann">Viessmann</option>
                 		<option value="Vokera">Vokera</option>
                 		<option value="Worcester">Worcester</option>
                 		<option value="Unknown">Unknown</option>
                 		<option value="Not Listed">Not Listed</option>
              		</select>
                </td>
  			</tr>
            <tr id="bmlpg">
                    <select name="lpg" id="lpg">
                 		<option value="0">LPG</option>
              		</select>
                </td>
  			</tr>
            <tr id="bmoil">
                    <select name="oil" id="oil">
                 		<option value="0">Oil</option>
                 		<option value="Buderas">Buderas</option>
                 		<option value="Danesmoor">Danesmoor</option>
                 		<option value="Firebird">Firebird</option>
                 		<option value="Grant">Grant</option>
                 		<option value="HRM">HRM</option>
                 		<option value="Nuway Oil">Nuway Oil</option>
                 		<option value="Thermeco">Thermeco</option>
                 		<option value="Trianco">Trianco</option>
              		</select>
                </td>
  			</tr>
so at the top of the code are the three buttons then after are the hidden elements.
Code:
#bmgas {
	display:none;
#bmlpg {
	display:none;
#bmoil {
	display:none;
this is the css hideing the elements
Code:
function addEvent(object, evName, fnName, cap) {
   if (object.attachEvent)
       object.attachEvent("on" + evName, fnName);
   else if (object.addEventListener)
       object.addEventListener(evName, fnName, cap);
addEvent(window, "load", init, false);
function init(){
	document.forms[0].fName.focus();
	document.forms[0].checked = showOptions;
	document.forms[0].onreset = refreshPage;
	document.forms[0].onsubmit = checkForm;
function show(obj){
    obj1 = document.getElementById('bmgas');
	obj2 = document.getElementById('bmlpg');
	obj3 = document.getElementById('bmoil');
    	obj1.style.display = '';
		obj2.style.display = '';
		obj3.style.display = '';
function showOptions(){
	if(document.fix.fuel1.checked == true){
		show('bmgas');
	}else if(document.fix.fuel2.checked == true){
		show('bmlpg');
	}else (document.fix.fuel3.checked == true){
		show('bmoil')
i cant for the life of me get this to work please help :)
Try setting display to 'block':
Code:
obj1.style.display = 'block';
obj2.style.display = 'block';
obj3.style.display = 'block';
I'd also suggest looking into jQuery. It'd make all of that code about 1/4 of the length.
no joy :( im determined to do this in javascript, i know JQ is easier and less code but i am learning atm and i want to understand how to do it
tried this as well..... nothing?
Code:
function showOptions(fuelType){
		document.getElementById('fuel1').style.display = "";
		}else if(document.fix.fuel1.checked == false){
		document.getElementById('fuel1').style.display = "none";
		document.getElementById('fuel2').style.display = "";
		}else if(document.fix.fuel2.checked == false){
		document.getElementById('fuel2').style.display = "none";
		}else if(document.fix.fuel3.checked == true){
		document.getElementById('fuel3').style.display = "";
		}else (document.fix.fuel3.checked == false){
		document.getElementById('fuel3').style.display = "none";
From having a quick skim you're handling the window load event, rather you'd add a listener to the radio option click event. I'd also suspect the addEvent function to produce errors, especially under IE, due to the if statement conditionals.
As Spunkey said, use a framework as it'll save you headaches otherwise just use the onClick event trigger attribute which will work. eg -
Code:
                    <input type="radio" name="fuelType" id="fuel1" value="Natural Gas" onClick="showOptions(this);" />
                      <input type="radio" name="fuelType" id="fuel2" value="LPG" onClick="showOptions(this);" />
                      <input type="radio" name="fuelType" id="fuel3" value="Oil" onClick="showOptions(this);" />
                </td>
Code:
function showOptions(obj){
    if (obj.id == "fuel1") {
        document.getElementById("bmgas").style.display = 'block';
        document.getElementById("bmlpg").style.display = 'none';
        document.getElementById("bmoil").style.display = 'none';
    } else if (obj.id == "fuel2") {
        document.getElementById("bmgas").style.display = 'none';
        document.getElementById("bmlpg").style.display = 'block';
    } else if (obj.id == "fuel3") {
        document.getElementById("bmoil").style.display = 'block';
Code:
                </td>
Code:
        document.getElementById("bmgas").style.display = '';
        document.getElementById("bmlpg").style.display = '';
        document.getElementById("bmoil").style.display = '';
ok we are 50% the way there, the desired effect i am after is that when the page loads none of the thre drop downs are present, then onclick the relevent drop down appears.
with this code all three drop downs are present but onclick two disapear.
any thoughts on how to achieve this?
done it, i managed to achive the desired effect by first having a function to initially set the display values of bmlpg and bmoil to none, then use the above code to dynamically change it.
many thanks visibleman
Why not just use the CSS that hides the dropdown table rows you posted in the OP?
This is what i used and it worked as intended ie: on page load, dropdown rows are hidden.
so the idea was once one of these three radio buttons were selected.........
Code:
<tr id="fuel">
<td width="230" valign="top" align="right">Fuel Type: </td>
<input type="radio" name="fuelType" id="fuel1" value="Natural Gas" onclick="showOptions(this);"/>
<input type="radio" name="fuelType" id="fuel2" value="LPG" onclick="showOptions(this);"/>
<input type="radio" name="fuelType" id="fuel3" value="Oil" onclick="showOptions(this);"/>
</td>
</tr>
a hidden options box would appear for the selected fuel type......
Code:
<tr id="bmgas">
</select>
<td>
</tr>
<tr id="bmlpg">
</select>
</td>
</tr>
<tr id="bmoil">
</select>
</td>
</tr>
to achieve this i have to hide the <tr>'s with the id's bmgas bmlpg and bmoil by first of all hiding them as the form loads
Code:
function showF1(){
	document.getElementById("form1").style.position = 'absolute';
	document.getElementById("form1").style.top = '190px';
		setOpacity("form1", 0);
		hide('bmgas', 'bmlpg', 'bmoil');        /* <<<<<<<<<<<<<<<<<<<<<---------- */
	document.getElementById("form1").style.zIndex = '1';
	document.getElementById("message").style.display = 'none';
	document.getElementById("fuel").style.display = '';
	document.getElementById("sevice").style.display = '';
	document.getElementById("message1").style.display = '';
		fadeIn("form1", 100, 0.7, 0);
	return false
function hide(obj){
    	       obj1.style.display = 'none';
		obj2.style.display = 'none';
		obj3.style.display = 'none';
i hope that helps
because i am learning javascript atm and this the way i wanted to do, plus older browsers and older ie dont support all current css without the use of javascript :(
I'm assuming that you're calling showF1() when the document loads? Unless you need to call the function again, then there isn't any real need to be using JS for initialising CSS. Instead you'd use plain-old CSS -
Code:
#bmgas, #bmlpg, #bmoil, #message {
	display: none;
#fuel, #sevice, #message1 {
	display: block;
#form1 {
        position: absolute;
        top: 190px;
        zIndex: 1;
Otherwise if you wanted to keep what you've got then the only thing that stands out is the hide() function. Firstly you don't need to parse parameters (you're also attempting to feed the function three different variables when the function is only set up for one) to the function as you're not making use of them, instead you'd call it using 'hide();' only; secondly it's a little inefficient as you're setting up object variables when you don't need to as you're not reusing them, instead -
Code:
function hide(){
    document.getElementById('bmgas').style.display = 'none';
    document.getElementById('bmlpg').style.display = 'none';
    document.getElementById('bmoil').style.display = 'none';
I'd also recommend grabbing a few of the Javascript books by O'Reilly, especially the reference book as it is always useful to have at hand.
Edit -
Granted but you need to be efficient rather than using JS for the heck of it. It'd be like using Flash for a simple animated image when a GIF would be the better solution.
IMO there's no real reason to learn Javascript these days. Head straight for the framework Jquery or MooTools. They're used pretty much everywhere.
Obviously there's a distinct difference between frameworks in the sense of PHP/Zend Vs JavaScript/jQuery
I do a lot of jQuery at work, but I never learnt JavaScript; though, getting the basics down isn't a bad idea.
*Just my opinion*
