So I'm looking at something like this:
YOUR BASKET
4 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** £59.99 (£239.96)
1 x Gigabyte F2A85XM-D3H AMD A85X Chipset (Socket FM2) DDR3 micro ATX Motherboard £58.99
1 x AMD A6-5400K Black Edition 3.60GHz (Socket FM2) APU Trinity Dual Core Processor (AD540KOKHJBOX) £49.99
1 x Corsair Builder Series CX 430w Modular '80 Plus Bronze' Power Supply (CP-9020058-UK) £38.99
1 x TeamGroup Elite 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £29.99
Total : £417.91 (includes shipping : FREE).
I already have a HDD to use for the Windows OS (others will be in a RAID 5 array).
Trying to find a small Micro-ITX case that supports 5 HDD's and is as cheap as possible - anyone have any suggestions?
I'd also like it to be as small as possible so I can fit it where needed (can get dimensions if required but it's a fairly good size).
I looked at the bitfenix, but it's a bit too tall/wide for what I was after
The only one that I've found that looks remotely ok so far is this:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-029-AE&groupid=2362&catid=2278&subcat=
But it's not brilliant (quite ugly but I guess does the job!).
YOUR BASKET
.The only one that I've found that looks remotely ok so far is this:
perfect list though thank you!
