Caporegime
- 8 Jan 2004
- Rutland
I would be tempted to remove, do a clean bend and refit.
Thanks will get some clips. See other people hammering bits of folded up lead (found one of these when I was cleaning out the mortar).I would be tempted to remove, do a clean bend and refit.
BTW, my limited undertanding is that you use flashing clips to secure it in the crevice, not cement, that just fills the gap.
But interested in anyone with actual experience!
Id remove the flashing, clean the joint and then do a fresh bend on the lead. Personally I wouldn't bother with clips, just make some wedges out of lead and hammer them home with a bolster, then mortar. Or get the guy back to do it properly.
Get the roofer back. He didn't fix it at all. It is meant to be sank 35mm in. Cowboy job.
Either way, a whole lot deeper than it is!25mm in the joint according to the lead association. See the other topic that was referenced![]()
yep this, looks to be what 5mm at the left :/Either way, a whole lot deeper than it is!
Thanks, I'll go get some clips and sealant. I've never made up mortar before so was thinking about using sealant.As previous posts I would folder a deeper top part on the lead, use clips or lead wedges to hold but I would then use one of the modern specialist lead flashing to brick sealants rather than mortar.
I've found these very durable even compared to mortar with something like SBR in and wetted brick work. They're easy to use as they stick to the lead and brick really well. The only extra effort is some care applying/smoothing but that's not hard to do and leaves a smart finish that won't crack with movement.
Lead mastic is what you are after. Just make sure you get a clean 90 degree fold on the lead (watch some lead beating videos; it is pretty simple). You may need a mortar rake on an angle grinder to cut out some more cement from that gap that isn't adequate.Thanks, I'll go get some clips and sealant. I've never made up mortar before so was thinking about using sealant.
I'll whip the whole piece out, get a better bend on it and sit it in the gap properly.Lead mastic is what you are after. Just make sure you get a clean 90 degree fold on the lead (watch some lead beating videos; it is pretty simple). You may need a mortar rake on an angle grinder to cut out some more cement from that gap that isn't adequate.
Edit: Don't bodge it as water will run behind the lead. I had a failed lead install and it was an absolute nightmare as the water made its way beneath the roof felt and the whole roof had to be ripped off.
Pretty sure we all want to see it. Probably not as bad as you think!God no. Nobody wants to see my crap handiwork. It's not pretty.
