Trying to push my R5 1600 to see what it can do (3.8ghz so far) but i'm not sure what voltage i'm pushing into it.
Ryzen Master says 1.40625v, HWinfo64 says the CPU Core (SV12 TFN) is 1.387v-1.394v, CPUID HWmonitor says Vcore is 1.392v (so plenty of droop and i've bought a board without LLC, AB350 Pro4, muppet
All are the most recent stable versions, which one is right? Am i already passed the "safe" 1.4v line or do i have some more headroom to push on to 3.9ghz? Already passed 5 minutes of HIGH Intel Burn In Test @3.8ghz
Set 1.4v in bios, it shows as 1.39v in bios after a reboot, shows as 1.425v in Ryzen Master, 1.425v in HWinfo64 & 1.425v in CPUID HWmonitor too.
After another reboot (still 1.4v in bios), HWINFO shows 1.412v at idle, Ryzen master shows 1.425v, CPUID shows VID of 1.425v but also has CPU VDD which floats between 1.394v - 1.425v
Under load (Intel BIT) CPUID CPU VDD drops as far as 1.338v, as does HWINFO, Ryzen Master still shows 1.425v (guessing its just a setup program not actual monitoring for voltages)
Is this just a terrible case of voltage droop? Do i need to front load my voltage (1.425v?) to make up for the droop under load? Or is there no "definite" right sensor to read for the Vcore?
