- 24 Dec 2007
Yeah, like the title says, I'm trying to attempt the tweak in which you copy the very high settings from the sys_spec files and paste it over the high settings.
The problem for me is that when I try to do this I get an error:
Cannot create the C:\Program Files\Electronic Arts\Crytek\Crysis\Game\Config\CvarGroups\sys_spec _GameEffects.cfg file
Make sure that the path and file name are correct.
Does anyone know what the problem is here? Because the path and file name are definately correct, and whenever I try to specifically overwrite the exact file, the same error occurs.
