Trying to get Fedora working in Parallels
29 Sep 2003
Newcastle upon Tyne
I'm trying to get Fedorar 7 working in Parallels. The OS installs just fine, but won't boot. When it tries to boot, the screen resolution flickers between high and low a few times (screen completely blank with a cross shaped cursor) then eventually comes up saying...
"The display server has been shut down about 6 times in the last 90 seconds. It is likely that something bad is going on. Waiting for 2 minutes before trying again on display :0".
If I press OK, it goes back to a black screen with the cross shaped cursor again, and just remains there.
How do I get this working?
Thanks,
Michael.
Somethings screwy with your Xorg...
Hit Ctrl-Alt-F1 to get to a command prompt.
In VPC you couldn't display 24bit graphics, first thing you had to do is to change it to 16. Although this doesn't sound like this problem.
# dmesg | tail
See if anything in there looks dodgy, or alterntively:
# cat /var/log/xorg.log
