Trying to get higher FSB with OCZ EB 2GHz?
27 Jan 2005
Expat in HK
Any thoughts on how I can hit 3GHz without water/phase. Let me know if you need anymore details.
simonnance said:
your RP and TRAS are also pretty tight, does loosening them let you push the ram to higher Mhz?
I tried loosening them, 3,6,6,10 with 2T, but alas I think it's stuck on 260-265MHz.
I set my memory divider to 133, then 166 and then 183, to see how far I could push the FSB and ended up with 270FSB max. See validation below. That's with tight timings and 1T.
http://valid.x86-secret.com/show_oc?id=156208
Unfortunately it craps out at 270Mhz stable even with the memory divider set to 133 (360DDR). I tried 300x10, 285x10.5, 275x11 and all booted fine, but couldn't get past the Windows login with slack timings of 3,6,6,10 and 2T.
