Hi!
Right now I am running a Q6600, Asus P5K-E, non overclocked in an Antec P180 with its 3 case fans at "low" setting. My CPU cooler is an Arctic Cooling Freezer Pro 7 which right now runs at 413rpm with temp 32C (according to Asus AI suite). According to Core Temp the temperature is around 39-40C. Other fans I have inside the system are the GTX260 (reference design) and the Corsair HX 620W.
What I want to succeed is to lower the noise while idle. I have my PC downloading in my office and I can barely hear it 6m away in my bedroom. While surfing or writing I can hear all the fans running...
In order to lower the noise I have decided to replace the 3 antec fans with at least 2 Coolink fans swif ultra silent (120mm, 800rpm, 11dB). However I am also trying to find a good heatsink (not to heavy as I have a vertical mounted mobo) with a variable fan.
After reading some discussions here, I see most of the people here suggesting Noctua, or Thermalright TRUE. These are big heatsinks but what about their fans. Are they variable? I have also seen Scythe Orochi which is pretty silent but huge and heavy. What would you suggest to me? I am interested more in noise than overclocking.
Thank you in advance!
