As title. I keep trying to overclock by fine tuning CPU voltage and FSB, but whenever I clock, after some usage the computer will freeze (even though the numbers on my sidebar CPU meter will still be moving). I'm pretty convinced this is RAM related.
CPU-Z shows a FSB : DRAM ratio of 3:10, is that what's causing it to freeze? It freezes even if I use the default 7% overclock option rather than manually.
DRAM Frequency currently running at 669.7 MHz, this is all with the standard numbers.
AMD Athlon II X4 635
ASUS M4N68T mobo
4GB RAM 1333MHz
Khare
ASUS M4N68T mobo
4GB RAM 1333MHz
Khare
