Hi all, posted something similar a week or so ago, but a few more questions needed! at the moment im @2.6 rock solid. idle 34 degs, max under prime on each core 50deg. Bios vcore is set to startup, but with the +6.6% option selected. fsb is at 217. mem on a div @ 2,3,2,5 1t (twin2048pc3200c2pt) (173=346ddr).
I can take the machine to 220 fsb with one degrees added on both idle and full. I need to hit 225 to reach 2.7 speed, but anything over 220 and the machine fails to boot into windows, logo appears then just resets. Will the jump to +9.9% from +6.6% solve? if so what are my temps likely to increase to? and would the temps still be safe for this processor?
colling is a SI-120 heat sink, Alaska 120mmfan, Arctic Silver5, Kandalf case.
Motherboard is MSI Neo 4 Platinum.
Thanks In advance
Ant.............
Thanks In advance
Ant.............
