Been asked to sort a laptop which has picked up "XP Smart Security 2010", one of the best written and effective pieces of malware i've ever seen!
System is pretty much unusable, popups every 20-30 seconds that steal the focus from what ever you are doing and block the center of the screen.
Malwarebytes won't run (or at least it does for a few seconds, then gets shut down.) Same for spybot & hijack this. MS essentials has had it's service stopped and it won't restart.
Pulled the drive and scanned it in another machine, Malwarebytes pulled out 30 odd dodgy files and 2 rootkit items. Back in the laptop and the virus is still there!
It won't boot in safemode, gets through the list of things it has started, then a flicker of bsod and it restarts from post. And you can't select the options for safemode and "don't reboot on bsod" at the same time, so i've no idea what is causing the crash. Boots fine if i don't select safemode though (apart from the whole virus thing)
All the fix-it pages tell me to open reg edit and fix a few entries, but "Registry editing has been disabled by your administrator."
Tried a few workarounds to reopen regedit, but no joy.
Used msconfig to stop everything at boot (safemode in everything but name basically) and the virus is still present!
Tell msconfig to reboot in safemode and now it is stuck in a reboot loop, it's treating "start windows normally" as "safemode" (because some idiot told msconfig to do it i suppose)
Last ditch idea, repair installation. Nope, "setup will not run in safemode", so now it's stuck in a setup/reboot loop.
I can pull the drive to another machine to tweak things, what file do i need to alter to tell msconfig to boot normally? OS is xp sp2.
Cheers
Cheers
