Trying to speed up a SQL function at work
18 Oct 2002
Hi all,
i'm looking to speed up a process LENGTHY at work and i don't know the best way to go about it. It's just to produce some reports for our call logging software, this scalar function brings in the hours remaining on a job. Does anyone have any advice at all? Would limiting the character size of the variables have a noticeable effect?
Code:
--get the time left on an issue
ALTER FUNCTION [dbo].[GetHoursLeftFULL]
    @IssueID int
RETURNS DECIMAL(20,10)
AS
BEGIN
    -- Declare the return variable here
    DECLARE @HoursLeftFULL DECIMAL(20,10)
    declare @HoursElapsed decimal(20,10)
declare @startdate varchar(20)
declare @enddate varchar(20)
declare @motion varchar(10) = 'Halt' --or 'Moving'
declare @engine varchar(10) = 'Stopped' --or 'Running'
declare @brakes varchar(10) = 'Applied' --or 'Released'
declare @mark varchar (20)
declare @seq smallint = 1
declare @entryline smallint = 1
declare @time datetime
declare @CompSLAHrs DECIMAL(20,10)
set @startdate = (select CAST(min(created) as date) from [VS019-GEMINI].[GEMINI].[dbo].gemini_issuehistory where issueid = @issueid)
set @enddate = (select CAST(GETDATE() as date))
declare @IssueEventsTemp table
    seq int,
    issueid int,
    history nvarchar(250),
    [time] datetime,
    mark nvarchar(30),
    entryline int,
    motion nvarchar(30),
    timeaccruedsecs int
with mycte as
         select cast(@startdate as datetime) DateValue
         union all
         select DateValue + 1
         from    mycte
         where   DateValue < @enddate
Insert into @IssueEventsTemp
SELECT ROW_NUMBER() over (ORDER BY time asc) as seq, *
FROM
    select @issueid issueid, 'BRAKES OFF' as history, dateadd(minute, 540, datevalue) as 'Time', 'BRAKES OFF' as 'mark', NULL as entryline, '          ' as motion, 0 as TimeAccruedSecs
    from mycte
    where LEFT(datename(weekday, DateValue), 3) not in ('Sat', 'Sun')
    and CAST(DateValue as date) not in (select holiday from [VS019-GEMINI].[GEMINI].[dbo].ListofHolidays)--prevents brakes off/on for holidays
    UNION ALL
    select @issueid, 'BRAKES ON' as history, dateadd(minute, 1050, datevalue) as 'Time', 'BRAKES ON' as 'mark', NULL as entryline, '          ' as motion, 0 as timeaccruedsecs
    from mycte
    UNION ALL
    select issueid, history, created as 'Time', case when history in ('Created','Issue status changed to Acknowledged', 'Issue status changed to Assigned', 'Issue status changed to Development Investigation','Issue status changed to Reopened', 'Issue status changed to Escalated', 'Issue status changed to In Progress') then 'ENGINE ON' ELSE 'ENGINE OFF' end as 'mark', NULL as entryline, '          ' as motion, 0 as timeaccruedsecs
    and (history = 'created' or history like 'Issue status%')
    UNION ALL
    select @issueid, 'ENGINE OFF', GETDATE(), 'ENGINE OFF', NULL, '', 0 --this line adds an engine off at the time of calling this function
) as data
WHERE EXISTS (select issueid from KPI2015 where timetostart = 0)
order by Time
OPTION (MAXRECURSION 0)
--adding in the marks
while (@seq <= (select MAX(seq) from @IssueEventsTemp))
begin
set @mark = (select mark from @IssueEventsTemp where seq = @seq)
set @time = (select Time from @IssueEventsTemp where seq = @seq)
if @mark = 'ENGINE ON'
begin
set @engine = 'Running'
end
if @mark = 'ENGINE OFF'
begin
set @engine = 'Stopped'
end
if @mark = 'BRAKES OFF'
begin
set @brakes = 'Released'
end
if @mark = 'BRAKES ON'
begin
set @brakes = 'Applied'
end
if (@brakes = 'Released' and @engine = 'Running')
BEGIN
set @motion = 'Moving'
END
if NOT (@brakes = 'Released' and @engine = 'Running')
BEGIN
set @motion = 'Halt'
END
--first time we get a Moving
IF (@motion = 'Moving' and @entryline = 1)
BEGIN
Update @issueeventstemp
set motion = 'Moving', entryline = @entryline
where seq = @seq
set @entryline +=1
goto wayout --exit the function
END
--other times we get a moving only write log if previous entry was a halt
IF (@motion = 'Moving' and @entryline <> 1)
BEGIN
    IF (select motion from @IssueEventsTemp where entryline = @entryline -1) = 'Halt'
        BEGIN
            where seq = @seq
            set @entryline +=1
        END
END
--if we get a halt, only write if previous entry was a moving
IF @motion = 'Halt'
BEGIN
    IF (select motion from @IssueEventsTemp where entryline = @entryline -1) = 'Moving'
        BEGIN
            set motion = 'Halt', entryline = @entryline
            where seq = @seq
            set @entryline +=1
        END
END
wayout:
set @seq +=1
END
--now add in the time accrued
update @issueeventstemp
set [@issueeventstemp].[timeaccruedsecs] = zxc.timeaccruedsecs
from @issueeventstemp
join
(select entryline, DATEDIFF(SECOND, (select time from @IssueEventsTemp where entryline = it.entryline-1), time) as timeaccruedsecs
from @IssueEventsTemp it
where motion = 'Halt') as zxc
on [@issueeventstemp].[entryline] = zxc.entryline
set @HoursElapsed =  (select SUM(TimeAccruedSecs)/3600.00 from @IssueEventsTemp)
--get the time to complete SLA time
set @CompSLAHrs = (select --gi.projectid, RIGHT(gip.prioritydesc, 2) as 'priority', gp.projectcode,
case when RIGHT(gip.prioritydesc, 2)='P1' then sla.P1Comp when RIGHT(gip.prioritydesc, 2)='P2' then sla.P2Comp when RIGHT(gip.prioritydesc, 2)='P3' then sla.P3Comp when RIGHT(gip.prioritydesc, 2)='P4' then sla.P4Comp end as SLAHours
 from
[VS019-GEMINI].[GEMINI].[dbo].gemini_issues gi
join [VS019-GEMINI].[GEMINI].[dbo].gemini_projects gp
on gi.projectid = gp.projectid
join [VS019-GEMINI].[GEMINI].[dbo].gemini_issuepriorities gip
on gi.issuepriorityid = gip.priorityid
join [VS019-GEMINI].[GEMINI].[dbo].zzsla sla
on gi.projectid = sla.projectid
    -- Add the T-SQL statements to compute the return value here
    SELECT @HoursLeftFULL = @CompSLAHrs-@HoursElapsed
    -- Return the result of the function
    RETURN @HoursLeftFULL
END
B@
Have you profiled the query to see where the choke points are? You can then start optimising those areas specifically.
Next to none I'd expect.
1. Look at the execution plan, see what part of it is taking up the time. This may suggest missing indexes.
2. Run the database engine tuning advisor on your workload. This may suggest missing indexes or missing statistics.
My gut feeling is you need to reduce the data on a daily/regular basis. Then report on this reduced data instead.
Feels more like this should be a procedure than a in-line/scalar function?
How often is this run?
Take a look at lead and lag? That's usually an effective way of building up cumulative totals from a series of transactions/records.
Run with the actual execution plan, as you can see where the expensive parts of your queries are and suggested indexes that can be added.
Update the calculated durations whenever a save is made, rather than whenever the page/data report is retrieved.
Then your page report can work out the time remaining itself, rather than asking the database to do it.
If you can't do that, then you'll need to look at optimising the retrieval of the data as quickly as possible (reducing the amount of data needed to look thru, optimising tablespaces, in-memory processing etc.)
I'd say you need to have a look at the logic before doing any profiling/optimising of the code you have. I can't tell without knowing your data, but surely there's a more efficient way of writing that?
Is this for SQL Server? Scalar functions are notoriously slow and looking at this one I don’t think it’s the right tool for the job at all. Table variables can be problematic as well, again when they’re being misused.
I think what you actually want here is a stored procedure to return not only the SLA but other details regarding the issue or any other reporting details. If you really do need re-usable logic for the SLA, to use it in other queries, then look into re-writing it as a table valued function as they can be inlined by the optimiser.
