Trying to stabilize tRCD/tRP and tRAS, would like advice
20 Dec 2020
Hi, I have a 4,133 MHz kit with primary timings of 15-20-20-37 on an Intel Z390 platform. Perfectly stable.
My VCCIO is set to 1.25V and my VCCSA is set to 1.20V.
I can boot into the PC at 15-19-19-36, but it will throw errors in TM5 after a short while. I've tried raising tRAS and VCCIO already, but to no avail.
Does anyone have experience with tightening tRCD/tRP in particular? If so, what did you need to do to get it to pass without errors?
In Thaiphoon, I have Micron B-die single rank RAM, and its default 2,133 MHz spec can run it at 15-15-15-36.
Thank you very much.
