- 2 Jul 2010
Hello there, i recently received a computer from my old employment area as they went bankrupt or some shizz nizz.
however they took the hard drive so i have to replace and use a new OS. however i wasn't sure if i should use 32bit or 64bit OS.
So i checked the bios and it was the most utterly retarded thing i had ever seen - that's dell for you - and i couldn't find many specs only that 64 bit was enabled.
Therefore logically i should be able to use 64bit i thought so i went ahead and ordered it. Then i read somewhere that this may not be the case so i neeed help!!!
how can i work out what OS is the right one to use
Specs from what i can work out:
Pentium 4ht @3.0ghz 3mb Cache
4GB RAM
retarded bios.....
thank youu.
4GB RAM
retarded bios.....
thank youu.
